Clube Samsung TV Plus
156
hello all, my first post, getting many of these channels relys on me having a log file from the tv set. Which can be created using a wifi hotspot app on a windows pc then connecting the tv to it.
such as
I need people who can provide me log files of samsung tv plus brasil.
I need to update my listings, so you can have more channels
Here are some channels i will be adding soon
Pocoyo (BR)
3 Palavrinhas (BR)
Cultne.tv (BR)
Canal L!ke (BR)
Novelisima em Português (BR)
Runtime (BR)
Toon Goggles (BR)
Sato+ (BR)
Fifa Plus (BR)
Go USA (BR)
The last log file i receive is only from the end of may and did not contain channels like Caze tv..
Who can help so everyone can enjoy?
desculpe por não escrever em português
228
such as
Pocoyo (BR)
3 Palavrinhas (BR)
Cultne.tv (BR)
Canal L!ke (BR)
Runtime (BR)
Toon Goggles (BR)
Sato+ (BR)
Fifa Plus (BR)
Go USA (BR)
I don't have Samsung TV, but I hope that someone could help you.
156
Canal LINEAR da CazéTV somente na Samsung e até agora não apareceu o link ainda.
Posso obter o link se as pessoas fornecerem o arquivo de log da Samsung TV, como escrevi. É muito fácil. Execute o hotspot wifi e conecte a TV a ele os URLs serão registrados basta escolher através de cada canal. Então me envie o arquivo txt do log. Eu farei o resto.
I can get the link if people supply log file from samsung tv, like I wrote. Its very easy. Run the wifi hotspot and conect the tv to it the urls will be logged just choose through each channel. Then send me the log txt file. I will do the rest.
Rai
2,414
such as
Pocoyo (BR)
3 Palavrinhas (BR)
Cultne.tv (BR)
Canal L!ke (BR)
Runtime (BR)
Toon Goggles (BR)
Sato+ (BR)
Fifa Plus (BR)
Go USA (BR)
Tem o link da tv cultura fast?
mvc
237
Não tenho smartv da Samsung, procuro links na internet mesmo, senão ajudava.
I don't have a Samsung smart tv, i look for links on the internet, otherwise it would help.
156
Hi guys, i just get to my pc and will start to check the logs now. As soon as get a result I will post
I need to filter the list first there is so much background traffic logged from netflix.
Olá pessoal, acabei de chegar ao meu pc e vou começar a verificar os logs agora. Assim que tiver resultado postarei
Preciso filtrar a lista primeiro, pois há muito tráfego em segundo plano registrado no Netflix.
156
Is this listing correct and in order?
Im trying to match it to the log file. That helps to identify things.
